Swedish podcasts
Posted: Mon Feb 13, 2012 6:03 pm
SvtPlay - http://www.svtplay.se
svtplay.zip
(113.52 KiB) Downloaded 2741 times
2. Drag and drop svtplay.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear SVT Play. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file svtplay.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder SVT Play, you can update the list of podcasts.
You can update the list of programs: select the folder "Kategorier" or "Program A-Ö" - right click - "Create podcast feeds"
Updated 2012/02/16 (support for flv and live streams)
Updated 2012/07/05
Updated 2012/07/10 (support for klipp)
Updated 2012/09/29
Updated 2012/11/03
Updated 2013/01/05
:!: Restriction of the region - Sweden
Re: Swedish podcasts
Posted: Thu Jul 05, 2012 1:09 pm
New version
Posted: Sat Sep 29, 2012 9:29 am
New version
Posted: Sat Nov 03, 2012 7:50 am
New version
Posted: Sat Jan 05, 2013 1:05 pm
New version
