Page 1 of 2
Subtitles go out of the screen
Posted: Tue Oct 11, 2011 9:13 pm
by 40HX700
Hi Everyone,
I use WMS in any situation pretty well but there's something i'd like to solve.
When watching movies with subtitles underneath, some subtitle lines are displayed out of the screen (the longer ones).
Is there any way for the subtitle lines to be always displayed on screen, even if there're long sentences (by reducing the subtitle width and impose a "carriage return")?
Thanks very much by advance.
Niko
Re: Subtitles go out of the screen
Posted: Wed Oct 12, 2011 9:31 am
00:00:06,798 --> 00:00:08,884
- vlcsnap-2011-10-12-13h27m11s99.png (245 KiB) Viewed 32099 times
Posted: Wed Oct 12, 2011 6:20 pm
by 40HX700
Thanks for giving me confidence in finding a solution by proving it's possible.
Did i modify a field somewhere ?
I know you're the man!
Here's what happends on my TV:
Posted: Wed Oct 12, 2011 6:39 pm
Possibly this is the result of scaling, the device has a mode "Original frame size" (or something like that) ?
Posted: Wed Oct 12, 2011 6:53 pm
Settings - Devices - choose a device - Settings - Transcoder - "Codecs, frame" - Frame - "Active padding color" - select a color, other than black, that the device will not be cut.
Posted: Wed Oct 12, 2011 7:47 pm
by 40HX700
I've tried the "Active padding color" thing, same result.
It may help you, it's cut on the right side of the screen only...
About the Frame Size: it's on "Minimum, fit to the screen"
Any other ideas Eugene ?
Thanks again
Niko
Posted: Thu Oct 13, 2011 7:36 am
Settings - Transcoder - "Temporary files directory" - specify the directory - Ok
List [Movies] - select a file - right click - "Test transcoding" - your device.
Play a file from "Temporary files directory" with your Windows player - check subtitles
Posted: Thu Oct 13, 2011 10:33 pm
by 40HX700
Hello Eugene,
I've done the transcoding test before asking about it : it's the same "spreading text problem" in the generated temp file:
I still can reinstall WMS but if could understand, that'd be better!
Posted: Fri Oct 14, 2011 4:44 am
Select a file - right click - "Test transcoding" - your device
What are the parameters of transcoding ?
Posted: Fri Oct 14, 2011 6:05 pm
by 40HX700
Hi There,
The usual profile is "movies (additionnal)"
Here's the dos windows when testing:
