Released version "Wild Media Server (UPnP) v1.11.8
Posted: Fri Aug 26, 2011 6:32 pm
Update file from version 1.10
How to update the program:
1. Download the update file.
The program can be updated from the distribution kit - http://www.wildmediaserver.com/download.php
- added device configuration "Samsung TV [C,D] (DLNA, 16:9, 720x406)", "Samsung TV (DLNA, 16:9, 1280x720)" renamed to "Samsung TV (DLNA, 16:9, 1280x720)", "Samsung TV (DLNA, 16:9, 1920x1080)" renamed to "Samsung TV (DLNA, 16:9, 1920x1080)".
- updated German translation file;
- fixed a possible problem (freezing) at scanning of BDMV-folder.
Update to version 1.11.2
- fixed the problem with disappearing settings "Client device access" and "Folder sort order";
- you can delete the folder "CD/DVD/BD Images (ISO)" and iso-images will be available in the folders "All ..." and "Media resources folders";
- updated transcoder rtmpdump.exe (temporary fix for "SWFVerification Type 2").
Update to version 1.11.3
- updated transcoder rtmpdump.exe (the problem (not worked) in Windows Service Mode on Windows x64);
- probably fixed the problem described in http://www.wildmediaserver.com/forum/vi ... f=3&t=1243
Update to version 1.11.4
- fixed the problem (wrong type of folder) with playlists in the folders "Internet-television" and "Internet-radio", links are not considered as Internet resources;
- updated Bulgarian translation file;
- fixed the problem (VLC does not open playlist) with xspf-playlists, if title of media-resource contains &.
Update to version 1.11.5
- fixed the problem (freeze) with starting server, if started the windows service "Routing and Remote Access";
- fixed the problem (premature termination) of transcoding profiles with multiple transcoders (1.11.4);
- changes at reading of ID3-tags on operating systems with an Oriental language by default;
- added configuration "Philips BD Player (UPnP, 16:9, 720x406)" (beta version);
- added configuration "Boxee Box (UPnP, 16:9, 720x406)" (beta version);
- added starting the server, when you turn on the mode "Install Windows service "Wild Media Server (UPnP, DLNA, HTTP)"" (Settings - Additional), for add rules of Windows Firewall.
Update to version 1.11.7
- added reading of keywords when scanning photos, added column "Keywords" in the table of photos, added folder "Keywords" to the section Photo;
- added ability to play rtmp-streams from any minute via the folder Transcoding (required field Duration);
- added Slovac translation file;
- added ability to save a list of media resources in HTML, XML, XLS, TXT, RTF formats (List [Movies, Music, Photo] - right click - "Save to file");
- added device configuration "Samsung Wave (DLNA, 16:9, 720x406)";
- added ability padding streams with null packets (Settings - Devices - choose a device - Settings - Transcoder - "Files, subtitles" - Padding), can be useful if the device interrupts the playback of transcoding content;
- updated device configurations for Samsung TVs (Padding - Suffix - 60 seconds);
- updated the transcoding profile "Internet-television" - added support for subtitles, added support for splash screen in beginning of video;
- added splash screen - tvsplash.mpg to the folder "?:\Program Files (x86)\Wild Media Server\Presentation\Images"; settings in the program - Settings - Devices - choose a device - Settings - Transcoder - "Files, subtitles" - "Internet-television" - "Splash screen"; unfortunately, VLC creates a stream with wrong timestamps, the device can interrupts the playback;
- added script "Scan folders", you can make the scan button on the main form of program (Settings - Processing - "Scan folders" - Edit - turn on "Button on the main form");
- updated transcoding profile "Movies - DirectShow - WMV", changes for Windows 7, added support for various formats of video files;
- updated subtitles module;
- added modes "Automatic addition of new devices", "Allow access for new devices" (Settings - Devices);
- added support for multi-angle DVD, restored support for changing titles of DVD-tracks;
- for wireless connections to the server name is added "- Wireless" (required re-adding connections in the settings of program - Settings - Server - "The list of authorized network connections").
Update to version 1.11.8
- added mode "Folder Transcoding in each folder of media-resources" (Settings - "Media-resources" - Service) - default on
- added setting for delay "Automatically scan directories when modified (creating, changing, deleting files)" (Settings - "Media-resources") default 60 seconds;
- added device configuration "Toshiba TV 2011 (DLNA, 16:9, 720x406)";
- updated transcoder ffmpeg-1.dll (fix for iso-files with national characters in filepath);
- fixed problems with "Create Date" and "Dimensions" of photos (version 1.11.7);
- fixed problem with deleting the subtitle track in the from "Movie information".
- Wild Media Server (UPnP, DLNA, HTTP) v.1.11
- 1. In transcoding options added file format MPEG1, video codec MPEG1.
2. In the configuration of devices added script to automatically determine the type of device
(Settings - Devices - choose a device - Settings - Type - the last button "Auto-detect type of device").
Setting for Autodetect mode - Settings - Devices - Autodetect.
3. Added ability for jumping to the form of the program localization (Ctrl + Shift + double click by control,
Ctrl + Shift + select a menu item).
4. Updated Bulgarian, German, Polish translation files.
5. Updated transcoder ffmpeg-1.dll (support for Composer, Conductor in m4a-files).
6. Updated transcoder rtmpdump.exe (support for justin.tv).
7. Changes for Panasonic devices (subtitles, settings for UPnP-sorting - Settings - Devices -
choose a device - Settings - Additional - "DLNA, UPnP options").
8. Added settings for default duration of internet-resources (Settings - "Media-resources" -
"Internet-resources" - "Internet radio"; "Internet - television").
9. Changes in the formation of DVD-structure. At scanning to the DVD-folder will be added links
of the main chapters of DVD;
10. Added new settings for DVD-structure (Settings - "Media-Resources - Scanning -
"Creating DVD structure folders for DVD-directories"):- "The minimum duration of the main chapters";
- "Hide DVD-structure folders (by default)".
12. Updated the transcoding profile "Movies - CoreAVC", added support for transcoding
avi, flv, mp4-files with H264 video encoding.
13. Updated the transcoding profiles "Internet-television", "Internet-television (Remux)",
added support for selecting the audio track;
14. Updated the transcoding profile "Music - RTMPDUMP - FFMPEG", added support for
the specified RtmpDump command line in the field Path.
15. Changes in Web-navigation for Firefox.
16. Added device configurations:- "VLC Media Player (Web, 16:9, 720x406)", can be used with any Internet Browser and VLC Media Player (free of charge);
- "Android 3.x (DLNA, 16:9, 1280x720)" (based on Android 3.x Pad dev conf & Transcoding profile).
18. Added transcoding profile "Movies (Remux)".
19. Added scripts processing media resources "Save metadata media resources (current folder)" and
"Load metadata media resources (current folder)".
