does your WMS supports the emtec s800h movie box ,,
it has got networking capablities ,has also got the ethernet ,,
i can do youtube on it ,,and internet stations on it via the ethernet connection
when i try to do it with the wms it doesnt work ,,i mean the tv showed incorrect file ,,and on internet radio it showd invaild file
i tried the internet radio , vlc on witv ,but it was working on my pc ,,but nothing on my emtec s800h  box which supports upnp
ive also got another box called hisense mp800h which also has got the upnp facilities ,,will this wms work on it ,,
i am using win vista ,,and connected to my boxes with wires ,,
any comments thanks
						WMS support for emtec s800h
Re: WMS support for emtec s800h
the above 2 boxex are simillar in hardware to playon hd,WD live .
it seems that you have compatibility with the above 2 boxes ,,
so how should i go ,,
ive downloaded the trial version if it works then i would buy it also ,,
but need some support to see ti works
ive tried changing the name of the device to dune ,,but still its showing invalid file and also no internet radio either ,,says invalid file ,,
any help
						any help
anybody there ,
to help me out ,
eugene come on where are you ,,
help me here,
how should i get it going on the emtec s800h ,
						to help me out ,
help me here,
