Released a version "Wild Media Server (UPnP) v1.04.7"
LouisXIV
Re: Released a version "Wild Media Server (UPnP) v1.04.5"
Post by LouisXIV »
Eugene wrote:- in the status bar of the main form of the program added mode "Automatic scanning
of removable media" (default is now off). Manual scan can be performed on right click
of the mouse on the folder "Removable media".
Thanks, it works :!: :!: :!:
Re: Released a version "Wild Media Server (UPnP) v1.04.7"
LiPe76 wrote: After upgrade to version 1.04.7 I don't need set compatible mode "WinXP" for playing video resource on Sony Bravia TV (Win7-64). Everythings work fine for me now.
Thanks for notice, I am glad :D
SiriusBlack
Post by SiriusBlack »
On my SONY BRAVIA KDL32EX709 I cannot watch DVBS(2) videos.
I am saving a DVB-S stream as .mpg on disk.
Media Info says MPEG-TS with: Video 166, MPEG Video version 2 and Audio 128, MPEG Audio version 1 layer 2, Text 68
BUT If I list the movie as a table, and click on "+", the MPEG-TS stream shows only one line: Audio MP3 192000, but no entry for video.
When I start playback there are just some fractals on the screen and the TV beeps just from time to time.
After switching on debug file generation and playback again the number of fractals increases signifcantly.
All other files play fine, as for example:
MPEG-PS with: Video 224, MPEG Video version 2 and Audio 192, MPEG Audio version 1 layer 2
MPEG-4 with: Video 1, AVC and Audio 2, AAC
AVI with: Video 0, MJPEG and Audio PCM
If I list these movies as a table, and click on "+", all stream shows one line for video AND one line for audio.
Example for MPEG-PS:
- Video MPEG2VIDEO 2376000
- Audio MP2 224000
Could it be that the MPEG-TS container is not properly read?
This would affect all DVB-S users.
SiriusBlack wrote:On my SONY BRAVIA KDL32EX709 I cannot watch DVBS(2) videos.
- Audio MP2 224000
Try change file extension to ts.
SiriusBlack
Thanks a lot, it worked!
Is there a skript possible to rename the filenames automatically, once they are added to the media database?
SiriusBlack wrote:Thanks a lot, it worked!
No, you can run renaming script before scanning.
Settings - Processing - Add
Name: Rename mpg-files
Check "Button on the main form"
Script:
  csSourceDirectory = 'C:\MpgFiles';
  Folder, FolderItem, ShellApp: Variant;
  i, iCount: Integer;
  ProcessMediaResult := False;
  if csSourceDirectory <> '' then begin
    ShellApp := CreateOleObject('Shell.Application');
    Folder := ShellApp.NameSpace(csSourceDirectory);
    iCount := Folder.Items.Count;
    for i := 0 to iCount - 1 do begin
      FolderItem := Folder.Items.Item(i);
      if not FolderItem.IsFolder then begin
        if SameText(ExtractFileExt(FolderItem.Name), '.mpg') then
          FolderItem.Name := ChangeFileExt(FolderItem.Name, '.ts')
    ProcessMediaResult := True
Need change csSourceDirectory
gugu
Post by gugu »
Got a couple of errors in 1.04.7-1.05 rc3.
1. When opening help:
2. After doing a group and then clicking on the mouse right button
error 2.jpg (132.47 KiB) Viewed 67601 times
Restarting program doesn't help.
The only way to restore the database is to delete the Movie collection folder (only through Structure of media resources) and then Restore folders to get the empty Collection folder back.
This error is not romanian language dependent. It does the same in english.
The error doesn't appear in Music collection folder. I also notest that trying to do a group from, say, Directors, actually puts into the group all the movies from Watch folders.
It has to be something wrong with the query you're doing in creating groups and/or creating a new group item into the the "Movie folders" record.
Cheers
gugu wrote:Got a couple of errors in 1.04.7-1.05 rc3.
I do not have this error, may be a new help file.
gugu wrote: 2. After doing a group and then clicking on the mouse right button
Thanks for notice, I think, that corrected this error.
gugu wrote: I also notest that trying to do a group from, say, Directors, actually puts into the group all the movies from Watch folders.
The grouping always process folders "All movies", "All Music", "All Pictures"
gugu
Post by gugu »
Check this out for hh_help_context called without a [map] section
http://www.codeguru.com/cpp/w-p/help/ht ... .php/c6513
Cheers
It may be useful information
Topic: Interface; Help Context: 105
From the program is called this topic.
