Released a version "Wild Media Server (UPnP) v1.04.7"
Re: Released a version "Wild Media Server (UPnP) v1.04.5"
So far, no playback problems with v1.04.3 on my Sony Bravia KDL-32W5710. My OS is Windows XP Pro.
Thanks for the informationLouisXIV wrote:So far, no playback problems with v1.04.3 on my Sony Bravia KDL-32W5710. My OS is Windows XP Pro.
You're welcome. I think I will not do another upgrade (V1.04.5) yet just to be sure I don't run into any problemsEugene wrote: Thanks for the information
Of course, you have a rightLouisXIV wrote:You're welcome. I think I will not do another upgrade (V1.04.5) yet just to be sure I don't run into any problemsEugene wrote: Thanks for the information
Whenever I drop a watched folder into collections and doesn't create the collection with the media anymore. This problem didn't happen in 1.03.
Concerning the problem with Sony W5500:
http://www.wildmediaserver.com/forum/vi ... 3247#p3247
or
Control - System and Security - Administrative Tools - Services - "Quality Windows Audio Video Experience" - Properties - click Stop, Startup type: Manual
or
Hi Eugene
Thank you for good tips.
Quality Windows Audio Video Experience Service I have set as you say, there is no problem.
But when I install version 1.04.5 again and set compatible mode to: Windows XP SP3 then everything works fine for me.
Problem with playing video resource on Sony Bravia KLD-32W5500 solved now.
Thanks again
Thanks again
Thanks for notice, perhaps it was necessary to restart WindowsLiPe76 wrote: Thank you for good tips.
Update on version 1.04.7
- added device configuration "AV Receiver" (music only);
- in the status bar of the main form of the program added mode "Automatic scanning
of removable media" (default is now off). Manual scan can be performed on right click
of the mouse on the folder "Removable media".
- changed transcoding profile "Movies - TsMuxer" for mode "Hide DTS in LPCM".
Re: Released a version "Wild Media Server (UPnP) v1.04.7"
After upgrade to version 1.04.7 I don't need set compatible mode "WinXP" for playing video resource on Sony Bravia TV (Win7-64). Everythings work fine for me now.
Great work. Thanks
Great work. Thanks
