Hulu support
Andrey
Re: Hulu support
Post by Andrey »
Eugene wrote:If let me know address the video page, then I can check.
Here it is:
http://www.hulu.com/watch/136714/chuck- ... 2Fepisodes
surfingsmurf
Re: Hulu support
Post by surfingsmurf »
surfingsmurf wrote: Only problem I can't seem to get it to play anything. I keep getting "video file cannot be played". I'm running the latest update.
Maybe solution http://www.wildmediaserver.com/forum/vi ... 1624#p1624
I'm able to view video from cnn and dailymotion, but others I can't like theWD, TV.com, etc.. It keeps coming up with "video file cannot be played". Any suggestion?
Re: Hulu support
surfingsmurf
Re: Hulu support
Updated, but still can't view any show on Hulu or theWB. I can view CNN and DailyMotion fine. How are they differ?
Thanks Eugene
Andrey
Re: Hulu support
Post by Andrey »
surfingsmurf wrote:I can view CNN and DailyMotion fine. How are they differ?
Are you from US? Did you try test transcoding?
surfingsmurf
Re: Hulu support
yes, I'm in the US and attached is what I get when test transcoding
Andrey
Re: Hulu support
Post by Andrey »
surfingsmurf wrote:yes, I'm in the US and attached is what I get when test transcoding
How did you update the wdf file? When I updated it via 'Load from file' menu, it had not really updated it. I had to remove Hulu folder and drop the hulu.wdf file again.
Your command line is different: it does not have "\\.\pipe\..."
Re: Hulu support
Try to open http://www.hulu.com and play anything http://www.wildmediaserver.com/forum/vi ... &f=3#p1636
surfingsmurf
Re: Hulu support
As you can see, I'm able to view http://www.hulu.com on the PC that is hosting WMS. Any other suggestions?
Re: Hulu support
surfingsmurf wrote: As you can see, I'm able to view http://www.hulu.com on the PC that is hosting WMS. Any other suggestions?
http://www.hulu.com/watch/141739/bones- ... n-the-pool - Any other suggestions?
