IPTV playlists
wildone1965
Re: IPTV playlists
Post by wildone1965 »
Thanks for your quick reply, but it still wont create the list. I even started WMS as admin in Vista. Any idea what i might be doing wrong?
Re: IPTV playlists
wildone1965 wrote:Any idea what i might be doing wrong?
wildone1965 wrote: I even started WMS as admin in Vista.
wildone1965
Re: IPTV playlists
I got the IPTV list added now. A lot of programs dont work at all. The ones that work with VLC wont play on my Sony TV though. Maybe the screenshot can help to solve the problem.
Re: IPTV playlists
wildone1965 wrote:I got the IPTV list added now. A lot of programs dont work at all. The ones that work with VLC wont play on my Sony TV though. Maybe the screenshot can help to solve the problem.
Settings - Transcoder - Profiles - "Internet television" - Restore
Rtsp-streams usually do not work through routers
isopor
Re: IPTV playlists
Post by isopor »
I have this URL for BBC: http://cctv.ws/5/625v31
It plays on Windows Media Player but not on VLC 1.1
Is it possible to put it in WMS ? How?
Re: IPTV playlists
isopor wrote:I have this URL for BBC: http://cctv.ws/5/625v31
For me and WMP does not play
isopor
Re: IPTV playlists
Post by isopor »
I checked and played it now with WMP (my version is a bit old: 10.00.00.4074)
I noticed that the real URL might be:
http://stream01.viewtv.co.uk/VODPlatformViewTV?Wyygpqb7qclEAEuYlrZb4uwDbnvXHhDxFS1iLtPm6AT24xzVAgiDO03nd0FVQpvG7mRU0YhnSmgd3eio_bkpIA!!
(This works too)
Or maybe:
mms://stream01.viewtv.co.uk/VODPlatformViewTV?Wyygpqb7qclEAEuYlrZb4uwDbnvXHhDxFS1iLtPm6AT24xzVAgiDO03nd0FVQpvG7mRU0YhnSmgd3eio_bkpIA!!&MSWMExt=.asf
(This doesn't work though).
Can you check again?
Re: IPTV playlists
(This works too)
Or maybe:
My mistake, I tried to play asx-file from response http://cctv.ws/5/625v31, if add http://cctv.ws/5/625v31, WMP plays video. I think the feature in the request header that sends WMP. If make such requests in WMS (like podcasts), I think will work, but needs analyse
Re: IPTV playlists
New profile:
Execute mode: Parameters
Language: PascalScript
Transcoder: VLC
  TranscodingParams := WmsTranscodingProfileParams('Internet-television');
  if WmsRegExMatch('REF HREF="(.*?)"', WmsDownloadURL(mpFilePath), InputFileName) then
    TranscodingParams := ReplaceStr(TranscodingParams, '<INPUT FILE>',
                                    ReplaceStr(InputFileName, 'http://', 'mms://'));
isopor
Re: IPTV playlists
Post by isopor »
Thanks, that works!
(To other users: I also set Language=PAscal Script and Transcoder=WMSMPEG)
