Page 3 of 19
Re: Podcasts Gallery
Posted: Mon Jun 14, 2010 8:46 am
ABC - Shows (http://abc.go.com/shows) (required version 1.0)
abc.zip
(11.22 KiB) Downloaded 4136 times
2. Drag and drop abc.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear ABC Shows. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file abc.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "ABC - Shows", you can update the list of podcasts.
Updated 2010/10/01
Updated 2011/03/02
Updated 2012/08/03
Posted: Thu Jun 17, 2010 8:15 pm
NBC - Shows (http://www.nbc.com/video) (required version 1.03)
nbcshows.zip
(5.22 KiB) Downloaded 4895 times
2. Drag and drop nbcshows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear NBC Shows. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file nbcshows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "NBC - Shows", you can update the list of podcasts.
Posted: Wed Jul 07, 2010 1:37 pm
G4TV (http://www.g4tv.com) (required version 1.75)
g4tv.zip
(4.37 KiB) Downloaded 3776 times
2. Drag and drop g4tv.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear G4TV. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file g4tv.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "G4TV", you can update the list of podcasts.
Updated 2010/07/08 - number of pages by default: 3 (G4TV - Edit title - "Script reading list of resources" - Edit - MaxPageCount)
Updated 2013/05/03
Re: ITV Player .. ?
Posted: Mon Jul 12, 2010 7:40 pm
Required version 1.51
itvplayer.zip
(24.89 KiB) Downloaded 4238 times
2. Drag and drop itvplayer.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear ITV Player. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file itvplayer.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "ITV Player", you can update the list of podcasts.
:!: Service only available in the United Kingdom :!:
:!: Periodically, you need to perform "Create podcast feeds" - select the folder "ITV Player" - right click - "Create podcast feeds" :!:
Updated 2010/10/13
Updated 2010/10/20
Updated 2011/02/07
Updated 2012/05/21 (added support for the mode "The script generates a few links (the call while navigating on the device)")
Posted: Tue Aug 03, 2010 10:41 am
by banafaen
http://corp.ign.com/feeds.html has some nice feeds for blyray/dvd movies, comics, tv and ofc all the consoles/pc games (like g4tc, gametrailers)
A lot of scripting needed for that site? :) (http://www.ign.com/)
-bana
Posted: Thu Sep 02, 2010 7:54 am
by JohnCSS
For what it's worth, I can't get them to work in IE or Chrome either.
However, if you have RealPlayer installed, you can download to your hard drive (with the right-click, 'Download with RealPlayer') and play them on your TV via WMS!
Eugene, on the same theme, can you put up a link for these 'Beatles' videos, maybe .....
http://www.beatlestube.net/video-links/
Posted: Thu Sep 02, 2010 8:47 am
JohnCSS wrote: Eugene, on the same theme, can you put up a link for these 'Beatles' videos, maybe .....
beatlestube.zip
(1.27 KiB) Downloaded 4424 times
Updated 2010/11/25
Updated 2011/01/11
Updated 2011/02/03
Posted: Sun Sep 12, 2010 2:50 pm
srinivas_av wrote:Can some one help here? (nothing related to WMS, I feel)
I have added youtube with the supplied zip file (included in the same topic)
And changed the Tag name as right click 'Podcasts->Youtube->Feeds for Tags And Users' and chose EditName
But the video are not sorted by the upload date? How can I change that RSS link so that the resultant videos are sorted according to 'upload date'?
...&orderby=published
http://code.google.com/apis/youtube/2.0/reference.html
Posted: Mon Sep 27, 2010 7:17 pm
by alarma
Eugene, could you add a podcast for http://www.rtve.es/alacarta/.
Something like the other TVs podcast. I do not know if it is possible.
Thanks in advance.
Regards.
Posted: Tue Sep 28, 2010 12:41 pm
alarma wrote:Eugene, could you add a podcast for http://www.rtve.es/alacarta/.
rtve.zip
(2.22 KiB) Downloaded 4363 times
Recomendados, Ultimos 7 dias, Temas, Todos A-Z, Archivo TVE
2010/12/29 Not working
