Podcasts Gallery
Re: Podcasts Gallery
ABC - Shows (http://abc.go.com/shows) (required version 1.0)
abc.zip
(11.22 KiB) Downloaded 4165 times
2. Drag and drop abc.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear ABC Shows. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file abc.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "ABC - Shows", you can update the list of podcasts.
Updated 2010/10/01
Updated 2011/03/02
Updated 2012/08/03
NBC - Shows (http://www.nbc.com/video) (required version 1.03)
nbcshows.zip
(5.22 KiB) Downloaded 4920 times
2. Drag and drop nbcshows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear NBC Shows. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file nbcshows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "NBC - Shows", you can update the list of podcasts.
G4TV (http://www.g4tv.com) (required version 1.75)
g4tv.zip
(4.37 KiB) Downloaded 3801 times
2. Drag and drop g4tv.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear G4TV. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file g4tv.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "G4TV", you can update the list of podcasts.
Updated 2010/07/08 - number of pages by default: 3 (G4TV - Edit title - "Script reading list of resources" - Edit - MaxPageCount)
Updated 2013/05/03
Re: ITV Player .. ?
Required version 1.51
itvplayer.zip
(24.89 KiB) Downloaded 4261 times
2. Drag and drop itvplayer.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear ITV Player. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file itvplayer.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "ITV Player", you can update the list of podcasts.
:!: Service only available in the United Kingdom :!:
:!: Periodically, you need to perform "Create podcast feeds" - select the folder "ITV Player" - right click - "Create podcast feeds" :!:
Updated 2010/10/13
Updated 2010/10/20
Updated 2011/02/07
Updated 2012/05/21 (added support for the mode "The script generates a few links (the call while navigating on the device)")
banafaen
Post by banafaen »
http://corp.ign.com/feeds.html has some nice feeds for blyray/dvd movies, comics, tv and ofc all the consoles/pc games (like g4tc, gametrailers)
A lot of scripting needed for that site? :) (http://www.ign.com/)
-bana
JohnCSS
Post by JohnCSS »
For what it's worth, I can't get them to work in IE or Chrome either.
However, if you have RealPlayer installed, you can download to your hard drive (with the right-click, 'Download with RealPlayer') and play them on your TV via WMS!
Eugene, on the same theme, can you put up a link for these 'Beatles' videos, maybe .....
http://www.beatlestube.net/video-links/
JohnCSS wrote: Eugene, on the same theme, can you put up a link for these 'Beatles' videos, maybe .....
beatlestube.zip
(1.27 KiB) Downloaded 4458 times
Updated 2010/11/25
Updated 2011/01/11
Updated 2011/02/03
srinivas_av wrote:Can some one help here? (nothing related to WMS, I feel)
I have added youtube with the supplied zip file (included in the same topic)
And changed the Tag name as right click 'Podcasts->Youtube->Feeds for Tags And Users' and chose EditName
But the video are not sorted by the upload date? How can I change that RSS link so that the resultant videos are sorted according to 'upload date'?
...&orderby=published
http://code.google.com/apis/youtube/2.0/reference.html
alarma
Post by alarma »
Eugene, could you add a podcast for http://www.rtve.es/alacarta/.
Something like the other TVs podcast. I do not know if it is possible.
Thanks in advance.
Regards.
alarma wrote:Eugene, could you add a podcast for http://www.rtve.es/alacarta/.
rtve.zip
(2.22 KiB) Downloaded 4391 times
Recomendados, Ultimos 7 dias, Temas, Todos A-Z, Archivo TVE
2010/12/29 Not working
