WTV h264 transcoding
ady72
Re: WTV h264 transcoding
Post by ady72 »
Great
tonight i will try it and then if everything is ok WMS will be mine!!!
Thanks a lot
ady72
Post by ady72 »
Hi Eugene after a thousands of try i'm already not able to transcode my wtv h264 files.I made test , transcoding starts and after about 2 minutes it stops for unknown reason.
At this point i think my pc miss something. Which are the requirements to install on pc after WMS (i mean some special codecs or software)?
Thank a lot in advance
Have a nice night
ady72 wrote:after a thousands of try i'm already not able to transcode my wtv h264 files.I made test , transcoding starts and after about 2 minutes it stops for unknown reason.
Anything additional it is not required (Windows Vista, Windows Seven, Windows 2008).
Unfortunately, there is currently no stability with video transcoding, but can be a problem to be solved.
ady72
Post by ady72 »
Ok so i'll wait with patience for it.For now thanks for everything
Merry Christmas and happy new year
wtvmpegps.zip
(2.79 KiB) Downloaded 884 times
2. Settings - Transcoder - Profiles - "Movies - DirectShow - WTV (MPEG-PS)" - Delete
3. Load - wmvmpegps.cfg - "Clear ... ?" - No
Profile can use a "CoreAVC Video Decoder" or "Microsoft DTV-DVD Video Decoder".
With "Microsoft DTV-DVD Video Decoder" can be problems with video quality, I do not know for what reason.
Transcoding works, but I only have short videoclips.
P.S. The problem was with hanging of transcoding, it has been solved, but perhaps not in all cases.
P.P.S Merry Christmas and Happy New Year :)
FFMPEG with wtv-support - file properties, thumbnails
http://www.wildmediaserver.com/test/ffmpeg-1.zip
1. Stop server, close program.
2. Unzip
3. Copy ffmpeg-1.dll to ?:\Program Files\Wild Media Server\
4. Start program
5. Select all wtv-files - right click - Load file properties.
Changes for transcoding profile "Movies - TsMuxer"
Settings - Transcoder - Profiles - "Movies - TsMuxer" - Edit
Find "function GetVideoFormat(aCodecID: Integer): string;"
Replace
if not SameText(mpFileType, 'mpegts') then
on
if not SameText(mpFileType, 'mpegts') and not SameText(mpFileType, 'wtv') then
Ok - Ok - Ok
Changes default profile of wtv-files
Default settings
Settings - "Media-Resources" - "File Types" - wtv - Edit - Transcoding profile - "Movies - TsMuxer" or "Movies (primary)"
Individual settings of device
Settings - Server - choose a device - Edit - Settings - "File Types" - wtv - Edit - Transcoding profile - "Movies - TsMuxer" or "Movies (primary)"
