Romanian translation
Help other users and get free licenses Wild Media Server (UPnP, DLNA, HTTP)
gugu
Re: Romanian translation
Post by gugu »
try this ones. I packed them rar now.
cheers
index_ro.rar
(1.54 KiB) Downloaded 2033 times
agenres_ro.rar
(2.63 KiB) Downloaded 2070 times
licence_ro.rar
(9.15 KiB) Downloaded 2069 times
gugu wrote:try this ones. I packed them rar now.
cheers
Thanks, I'll include the files in the next version (just a duplicate index_ro)
P.S. If you rename the files in index_ron.htm, agenres_ron.xml, they will be used now
gugu
Romanian translation 1.04.7-1.05 release candidate 3
Post by gugu »
Cheers
romanian 1.04.7-1.05 rc3.rar
(59.36 KiB) Downloaded 2102 times
gugu
Post by gugu »
error 3.jpg (127.48 KiB) Viewed 52738 times
1. gpTranscodingDefaultLanguage probably should be "Default language for subtitles".
2. gpTranscodingDefaultAudioLanguage "Язык звүқовых дорожек по-умолчанию" probably should be "Default language for audio track" and should be localized and added to the language editor.
Cheers
gugu wrote: 1. gpTranscodingDefaultLanguage probably should be "Default language for subtitles".
Try to restore a localization file from the distribution (Help - Select language - Restore)
gugu
Post by gugu »
I actually did restore localization from distribution.
I think you have had a single language field for both subtitles and audio (gpTranscodingDefaultLanguage ) and you wanted to have separate language
fields for subtitles and for audio (gpTranscodingDefaultLanguage which you kept for subtitles only and gpTranscodingDefaultAudioLanguage for audio).
Thus, the first change translation from "Language of subtitles and audio tracks by default" to "Default language for subtitles", and second becomes "Default language for audio track".
Is this right ?
If yes, the problem is the second field, gpTranscodingDefaultAudioLanguage, is missing from localization tree, thus is impossible for me to translate the second.
Because missing it takes the default russian version of the text.
Cheers
Is this right ?
Sorry, my mistake, the file with new values for gpTranscodingDefaultLanguage and gpTranscodingDefaultAudioLanguage, not get into the update file.
New default.wln
default.zip
(118.87 KiB) Downloaded 2226 times
gugu
Post by gugu »
Made the proper modification into romanian.wln
Cheers
romanian 1.04.7-1.05 rc3 v2.rar
(59.32 KiB) Downloaded 2086 times
gugu
Post by gugu »
1.05
Cheers
romanian 1.05.rar
(59.41 KiB) Downloaded 2052 times
