Megavideo and WMS
Re: Megavideo and WMS
paltibet wrote:
I am testing WMS and it works really well.
About Megavideo, I did follow all the Eugene's instructions but it didn't work, I could not load the example video.
I tested MTV and it works perfect and I follow the same way.
"Add link" in List [Movies]
paltibet
Post by paltibet »
Eugene wrote:Hello,
Sorry :oops:
It works without problems.
Thank you Eugene
Carnero, what about 72'? Do you fix it?
One more question Carnero: do you speak spanish? If yes send me a pm please.
KingNothing
Post by KingNothing »
Hi, thank you for this great piece of software that is WMS.
I would like to know if there is any solution for the 72 minutes limitation for megavideo.
Anyone could help me in solving this ???
Thank you again...
pcr
Post by pcr »
Can I ask, when adding this type of resource, should the links under Megavideo appear automatically, or is it neccessary to add a link manually for each video video as required ?
Thanks, pcr.
pcr wrote:Can I ask, when adding this type of resource, should the links under Megavideo appear automatically, or is it neccessary to add a link manually for each video video as required ?
Thanks, pcr.
Yes, add a link manually for each video.
jarodsc
Post by jarodsc »
I have the podcast Megavideo with my id of premium account for megavideo.
But how to add a link for a video, i do Add link on the right, but in this form where to put the link.
Thank you
Add link - Movie Information - File - Path
megavideo.zip
(2.7 KiB) Downloaded 1232 times
Megavideo with Search subfolder.
Megavideo - Search - right click - Add podcast - Title - keyword
iphos
Post by iphos »
Hi guys, I have a BR sony bdp-s570, and I have noticed that, even if megavideo links work fine on my pc, my wms is able to recognize just the megavideo link that have the string /?v on the url, i.e.
like this: http://www.megavideo.com/?v=...
no way to make it works if url contains /?p
like http://www.megavideo.com/?p=..
any suggestion?!
