Can't access WMS from Sony Bravia KDL 46 EX 505 TV
wildone1965
Re: Can't access WMS from Sony Bravia KDL 46 EX 505 TV
Post by wildone1965 »
Did it as shown in screenshot. Still no access. Btw, thank you for your help and patience Eugene.
wildone1965 wrote:Did it as shown in screenshot. Still no access. Btw, thank you for your help and patience Eugene.
Sorry, my fault, remove all from "A list of allowed client devices".
wildone1965
Great...yes....thanks my friend....see screenshots...I can now access WMS through Webbrowser but still not from TV. Hope we will get this problem solved too.
wildone1965
I did a new server search on the TV and it pisplays now a second WMS. a bit confusing ...good news though....I can access the server ....now i will start testing the resolution and sound features.....
Thank you so much my friend
wildone1965
It actually did change, now i need to find out how to clear the listed old server from the TV-Screen. And i am also having a bit of stuttering on blue ray movies, so i have to work prolly on the setting for transcoding and/or buffering.
wildone1965
Hide what excately?
I just found a setting to prevent stuttering of MKV Files with 1080p.
Find empty space on a harddrive to buffer the transcoded files. Use the follwing settings
go to the MKV File and right click on the file and set transcoding profile to Movies-TsMuxer as shown below
wildone1965
I havent seen the HIDE function yet. Where is it? On your remote control?
wildone1965
Worked perfect....Thx Dan
wjzbj
Post by wjzbj »
wildone1965 wrote: thank you for your quick response, but unfortunately your tip didnt help. I still cant access the server from the TV. In case you need some additional information or screenshots let me know.
Log messages in main form of program ?
Try to open a presentation page in the Internet Explorer: http://server_ip_address:port
I try to open a presentation page in the IE, but nothing displayed.
I can see the server IP address on my TV screen. But it says connot get the server name. Why?
Probably access to the server closed the firewall. Which the error code in IE?
