IPTV playlists
Re: IPTV playlists
Klausi69 wrote:Thanks for your quick response.
The test transcoding fails.
Sorry, my mistake
Before
     sTranscodingParams := WmsTranscodingProfileParams('Movies (Primary)');
insert a line
     mpInternetItem := False;
Tested on http://cctv.ws/8/TV2lq/ITV2LQ
Klausi69
Re: IPTV playlists
Post by Klausi69 »
I changed the profile as described but there are still error messages (tested with your URL):
Re: IPTV playlists
Klausi69 wrote:I changed the profile as described but there are still error messages (tested with your URL):
Network problems ? I checked now, no problems for me.
Klausi69
Re: IPTV playlists
Post by Klausi69 »
No network problems. I even created the profile again but the messages remain. So I fail to act. :oops:
Re: IPTV playlists
Klausi69 wrote:No network problems. I even created the profile again but the messages remain. So I fail to act. :oops:
Have you checked the play in VLC ? Stable ?
Klausi69
Re: IPTV playlists
Post by Klausi69 »
Yes, in VLC it is very stable.
Re: IPTV playlists
Klausi69 wrote:Yes, in VLC it is very stable.
At the start I also have messages of problems with the stream - this is normal, then transcoding without problems.
Klausi69
Re: IPTV playlists
Post by Klausi69 »
Eugene wrote:If the loading is successful, then in folder "Internet-television" appear IPTV links. If IPTV links does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights.
In this case I would appreciate to open the playlist (e.g. xspf) by context menu. It's a little bit boring to switch off UAC every time when updating the playlist. Perhaps you can add this possibility in one of your next versions. I'm only able to add .wdf-files:
Re: IPTV playlists
Perhaps the program was launched from the installer.
Klausi69 wrote: Perhaps you can add this possibility in one of your next versions. I'm only able to add .wdf-files:
Perhaps
wildone1965
Re: IPTV playlists
Post by wildone1965 »
Hello Eugene, hello everyone else,
i try to add the "IPTV" playlist. It shows up on VLC Player, but it won't show up on WMS - Internet Television Folder. I am using Windows Vista Home Premium. If someone can please help me with this and post screenshots. Its much easier to work with screenshots, since there are so many settings and adjustments to play with.
Wildone
