BBC IPlayer Not Working
rooster
Re: BBC IPlayer Not Working
Post by rooster »
Where are you highlighting podcasts ?
When I open the WMS window, I see MOVIES, MUSIC, PHOTO etc across the top menu bar... the only place I can see podcast is near the bottom of the movies tree... and the downloaded file (bbc iplayer.wdf) doesnt want to be dragged anywhere on the screen ! :oops:
bubblegum
Post by bubblegum »
Movies selected at the top,
Highlight podcasts, on the left near bottom of the page. Try right click, load from file, or drag the file to right
The bbc iplayer should appear under podcasts on left.
Then update podcasts.
You should then see a grey bar loading new podcasts.
rooster
Post by rooster »
MANY thanks for all your help... now have the Iplayer tree under podcasts, but cannot see where to update ! :oops:
bubblegum
Post by bubblegum »
Right click podcasts, Update podcast
rooster
Post by rooster »
bubblegum wrote:Right click podcasts, Update podcast
You sure ? Mine doesnt seem to have that ! v0.73
bubblegum
Post by bubblegum »
Just checked, mine does. My version is the latest.
http://www.wildmediaserver.com/forum/vi ... ?f=3&t=344
rooster
Post by rooster »
Right - upgraded to v1 and now the "update podcast" works... BUT when I try to play anything, it starts to load, then the title jumps to the next in the list !!!!!!
AAAARRRGGGG why cant this be simple ? :evil:
bubblegum
Post by bubblegum »
Hi, now I can't use BBC iplayer.
I have tried different Transcoding profiles. Removed BBC iplayer from podcasts, then putting it back in.
Any ideas?
Youtube & gametrailers work ok.
bubblegum wrote:Hi, now I can't use BBC iplayer.
Any ideas?
BBC iPlayer - Edit title - Script for links to the resource - Edit
Try commenting out
                end{ else if SameText(sApplication, 'a1414/e3') then begin
                  MediaResourceLink := Format('--playpath "%s?%s" --host %s --swfUrl %s --tcUrl rtmp://%s:1935/a1414/e3 --app a1414/e3',
                                              [ConnectionItem.Attributes['identifier'],
                                               ConnectionItem.Attributes['authString'],
                                               ConnectionItem.Attributes['server'],
                                               'http://www.bbc.co.uk/emp/10player.swf?revision=15501_15796',
                                               ConnectionItem.Attributes['server']]);
                  Break
                end }
bubblegum
Post by bubblegum »
That seems better, some are working, but some give "error number -2"
