Re: WMS doenstn play the Last 15 Seconds....
Posted: Fri Nov 05, 2010 2:46 pm
thank you for your reply, I'll try that
Forum of program "Wild media server (UPnP, DLNA, HTTP)
http://www.wildmediaserver.com/forum/
Eugene wrote:If your TV does not support Chunked mode, you can use the settings "Close connection after transcoded file transfer in ? seconds" (Settings - Device)vincek02 wrote:I want to fix the problem of the last second but i can't use the chunked mode to fix it because freeze, or tell me which setting to use with chunked mode to solve freeze probleme.Eugene wrote:If transcodes in m2ts-format, check the DLNA-profile, it should be MPEG_TS_HD_NA_T (Settings - File types).vincek02 wrote:The problem is the sameEugene wrote:Have you tried playing movies in the mode Chunked without transcoding ? Any problems?
My device is samsung UE32C5100, What are the best settings to avoid this?
I'm confused, the problem with periodic freezes or absence of the last seconds ?
I checked on Samsung BD Player, 15-seconds video - complete playback with transcoding.
Settings - Server - choose device - Edit - Settings - "Close connection after transcoded file transfer in ? seconds"vincek02 wrote:Eugene wrote:If your TV does not support Chunked mode, you can use the settings "Close connection after transcoded file transfer in ? seconds" (Settings - Device)vincek02 wrote:I want to fix the problem of the last second but i can't use the chunked mode to fix it because freeze, or tell me which setting to use with chunked mode to solve freeze probleme.Eugene wrote:If transcodes in m2ts-format, check the DLNA-profile, it should be MPEG_TS_HD_NA_T (Settings - File types).vincek02 wrote:The problem is the sameEugene wrote:Have you tried playing movies in the mode Chunked without transcoding ? Any problems?
No change with this method, another idea?
I already tested it without successEugene wrote:Settings - Server - choose device - Edit - Settings - "Close connection after transcoded file transfer in ? seconds"
The original file and the test transcode file contains lost video?vincek02 wrote:I already tested it without successEugene wrote:Settings - Server - choose device - Edit - Settings - "Close connection after transcoded file transfer in ? seconds"
