Posted: Thu Jan 14, 2010 4:43 pm
works for me too =-)
Forum of program "Wild media server (UPnP, DLNA, HTTP)
http://www.wildmediaserver.com/forum/
Settings - Transcoder - "Codecs, frame" - change "File format" to "MPEGTS"michiel1981 wrote:really tried everything possible but i cant get it to stream hd files anymore, screen just goes black and audio playing but its not streaming since i can use the options on my remote. I reinstalled several times but no luck.....
something is wrong with ts muxer profile when is set primary profile it plays but stutters since it aint streaming and when i set tsmuxer the screen just hangst or goes black and audio plays but i an still use the remote keys which i shouldnt be able too so no streamingEugene wrote:Settings - Transcoder - "Codecs, frame" - change "File format" to "MPEGTS"michiel1981 wrote:really tried everything possible but i cant get it to stream hd files anymore, screen just goes black and audio playing but its not streaming since i can use the options on my remote. I reinstalled several times but no luck.....
or
Settings - Transcoder - "Temporary files" - Transcoding file params - Movies - select extension mpg
Unfortunately, Sony does not play all the content H264, this frame size can not be supported.michiel1981 wrote:something is wrong with ts muxer profile when is set primary profile it plays but stutters since it aint streaming and when i set tsmuxer the screen just hangst or goes black and audio plays but i an still use the remote keys which i shouldnt be able too so no streamingEugene wrote:Settings - Transcoder - "Codecs, frame" - change "File format" to "MPEGTS"michiel1981 wrote:really tried everything possible but i cant get it to stream hd files anymore, screen just goes black and audio playing but its not streaming since i can use the options on my remote. I reinstalled several times but no luck.....
or
What problems?braviabob wrote:Eugene - do you know where I can find the standards excepted by the TV so I can encode/transcode my existing files.
I have tried and failed to encode several DVD's using tools like ImToo with no luck.
Description is in this document http://www.wildmediaserver.com/files/DO ... 1%5D.0.pdf. But it does not bind to the video codec.braviabob wrote: I've had this from the official forum and googled the types but it doesn't seem to tell me much.
MPEG2_PS_SD MPEG2
MPEG2_TS_EU SD MPEG2
MPEG2_TS_EU-T SD MPEG2
MPEG2_TS_EU-ISO SD MPEG2
MPEG2_PS HD MPEG2
MPEG2_TS_EU HD MPEG2
MPEG2_TS_EU-T HD MPEG2
MPEG2 TS_EU-ISO HD MPEG2
MPEG2_TS_EU SD H.264
MPEG2_TS_EU-T SD H.264
MPEG2_TS_EU-ISO SD H.264
MPEG2_TS_EU HD H.264
MPEG2_TS_EU-T HD H.264
MPEG2_TS_EU-ISO HD H.264
