michiel1981
Post by michiel1981 »
works for me too =-)
braviabob
Post by braviabob »
I've done the recommended and the majority of my h.264 files work well but I have a problem when I try to stream a HD file. It does the test transcode well and works in VLC. Unfortunately the TV picture isn't right just a mess although the sound is coming through, I get the same result when playing the test file via usb?
michiel1981
for some reason the same thing is happening for me aswell even with movies that worked before i dunno whats changed but for some reason its not streaming anymore since i can use the pauze key. I think all thats different is that i updated the version to .2
michiel1981
really tried everything possible but i cant get it to stream hd files anymore, screen just goes black and audio playing but its not streaming since i can use the options on my remote. I reinstalled several times but no luck.....
michiel1981
test
michiel1981 wrote:really tried everything possible but i cant get it to stream hd files anymore, screen just goes black and audio playing but its not streaming since i can use the options on my remote. I reinstalled several times but no luck.....
Settings - Transcoder - "Codecs, frame" - change "File format" to "MPEGTS"
or
Settings - Transcoder - "Temporary files" - Transcoding file params - Movies - select extension mpg
michiel1981
or
something is wrong with ts muxer profile when is set primary profile it plays but stutters since it aint streaming and when i set tsmuxer the screen just hangst or goes black and audio plays but i an still use the remote keys which i shouldnt be able too so no streaming
or
Unfortunately, Sony does not play all the content H264, this frame size can not be supported.
You can use this advice http://www.wildmediaserver.com/forum/vi ... p=202#p202
braviabob
Post by braviabob »
Eugene - do you know where I can find the standards excepted by the TV so I can encode/transcode my existing files.
I have tried and failed to encode several DVD's using tools like ImToo with no luck.
I've had this from the official forum and googled the types but it doesn't seem to tell me much.
MPEG2_PS_SD MPEG2
MPEG2_TS_EU SD MPEG2
MPEG2_TS_EU-T SD MPEG2
MPEG2_TS_EU-ISO SD MPEG2
MPEG2_PS HD MPEG2
MPEG2_TS_EU HD MPEG2
MPEG2_TS_EU-T HD MPEG2
MPEG2 TS_EU-ISO HD MPEG2
MPEG2_TS_EU SD H.264
MPEG2_TS_EU-T SD H.264
MPEG2_TS_EU-ISO SD H.264
MPEG2_TS_EU HD H.264
MPEG2_TS_EU-T HD H.264
MPEG2_TS_EU-ISO HD H.264
regards,
Bob
braviabob wrote:Eugene - do you know where I can find the standards excepted by the TV so I can encode/transcode my existing files.
What problems?
braviabob wrote: I've had this from the official forum and googled the types but it doesn't seem to tell me much.
MPEG2_PS_SD MPEG2
MPEG2_PS HD MPEG2
Description is in this document http://www.wildmediaserver.com/files/DO ... 1%5D.0.pdf. But it does not bind to the video codec.
