Hello Eugene, I bought and installed CoreAVC. It works great! I'm getting about 85-95% CPU usage, and 50fps average decoding speed!Eugene wrote: Hi,
Try use the transcoding profile "Movies - CoreAVC" (select a file - right click - Transcoding profile - "Movies - CoreAVC")
FFDShow codec maybe required
 Thank you very much!
 Thank you very much!However, I think image quality was richer before, using wmsmpeg. Is there a way to tell CoreAVC to use a better quality profile, reducing fps speed (to 30 or 35) but producing better video?
