Just a quick note to say that tonight I upgraded to the 1.00 version and the DVB subtitles are working correctly. The workaround to set the “Frame size” to 720x406 and “Format” to 16:9, also sorted out the aspect ratio problem. So it is all working now.
Is there a way of setting the transcoder settings so the subtitles are always on. My family are fairly bad at anything involving technology and I can't see them remembering how to turn the subtitles on for each title.
Cheers
John
new Sony HD TV and DVB subtitles
Re: new Sony HD TV and DVB subtitles
The easiest way is to select a subtitle track after a scan manually or using a script processing media resources (set property mpiSubtitleLanguage)jolson wrote: Is there a way of setting the transcoder settings so the subtitles are always on. My family are fairly bad at anything involving technology and I can't see them remembering how to turn the subtitles on for each title.
