and Happy New Year.
I wish you all the best!
I have some troubles setting subtitles' font.
Previously it was possible to set the font through device's settings page.
Now nothing happens when I try to change it from Arial to anything else. Only the style could be changed (Regular, Italic, etc.)
But when another font is selected the button shows Arial again.
I have tested with WMS 2.0 and 2.01 on Windows XP/x86 and Windows 8.1/x86 (UAC disabled). The result is all the same.
The last version on which I could confirm that the font selection works is 1.79.1. I haven't tested anything else between those versions.
There must be something between them that changed the normal behavior.
Regards.
