Podcasts Gallery
Re: Podcasts Gallery
CWTV - Shows (http://www.cwtv.com/shows/) (required version 1.75)
cwtv_shows.zip
(3.77 KiB) Downloaded 6217 times
2. Drag and drop cwtv_shows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear CWTV - Shows. If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file cwtv_shows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "CWTV - Shows", you can update the list of podcasts.
:!: Thumbnails available in the United States only :!:
Updated G4TV
NBC - Shows (http://www.nbc.com/) (required version 1.75)
nbc_shows.zip
(6.59 KiB) Downloaded 6296 times
2. Drag and drop nbc_shows.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "NBC - Shows". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file nbc_shows.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "NBC - Shows", you can update the list of podcasts.
Updated TheWB-Shows
Updated Marvel
Updated ESPN
Channel4 - PS3 (http://ps3.channel4.com/) - required version 1.75.1 (64-bit), 1.75.1 (32-bit)
channel4_ps3.zip
(202.39 KiB) Downloaded 6381 times
2. Drag and drop channel4_ps3.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear "Channel4.com (PS3)". If the folder does not appear (Windows8, Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file channel4_ps3.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder "Channel4.com (PS3)", you can update the list of podcasts.
:!: Service only available in the United Kingdom :!:
Subtitles support: select the folder "Channel4.com (PS3)" - Edit title/settings - Transfer - "Additional parameters" -
--subtitles=on
