Podcasts Gallery
Re: Podcasts Gallery
Updated Hulu
Updated ESPN
Updated Tou.tv,
STV Player (http://player.stv.tv/) (required version 1.57)
stvplayer.zip
(14.73 KiB) Downloaded 2830 times
2. Drag and drop stvplayer.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear STV Player. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file stvplayer.wdf by right click in the folder tree.
By the right mouse button in the folder tree on selected subfolder STV Player, you can update the list of podcasts.
Updated Youtube - added support for folder "Search Text"
Updated Youtube
