There are lots of great shows on http://revision3.com/.
Unfortunately I don't have the ability to script like some of you here!
I'd really love to have all the shows, but especially http://revision3.com/destructoid and http://revision3.com/newchallenger!
If anyone with the talent and time to create a script can do so I would be greatly appreciated.
Isaac
Podcasts Gallery
Re: Podcasts Gallery
Try this
Go to http://revision3.com/destructoid or http://revision3.com/newchallenger
Find the section RSS FEEDS at the middle left side of page.
Choose what you want, go to that page and copy its address (link).
At WMS right click on Podcasts choose Add Podcast
Give it a Title and paste the address (link) in the Link field, push the OK button
Right click on the podcast you has created and choose Update Podcasts
Enjoy
ramaral
Enjoy
ramaral
Updated BBC iPlayer (added support for the mode "The script generates a few links (the call while navigating on the device)")
Updated ITV Player (added support for the mode "The script generates a few links (the call while navigating on the device)")
Updated Australian Channel Ten (added support for the mode "The script generates a few links (the call while navigating on the device)")
sebarosales
Hello! This is my first post and contribution to this great software.
I have made a script called 'Youtube - Music' that gets music Weekly Top 100 (http://www.youtube.com/charts/videos_views/music) and Billboard top 20 (http://www.youtube.com/playlist?list=BB20120825).
Note that these special playlists can't be obtained by rss feeds because YouTube doesn't provide any APIs to access them. My scripts get playlists url and then they use Eugene YouTube script to get media urls.
I made two different versions. One is Eugene's YouTube script with my folder added, the other is my script only in case you want it as a separate item.
Instructions (required version 1.51):
2. Drag and drop 'Youtube.wdf' or 'Youtube - Music.wdf' from Explorer to main form of program.
I hope you like it and if you have any questions or problems just tell me.
- Youtube_Music.zip
- (11.71 KiB) Downloaded 3368 times
KingNothing
Is it possible to create a script for nowvideo ?
An example of link is the following :
http://www.nowvideo.co/video/c62bea684fc37
Thanks in advance...
Updated Gametrailers.com
