Is it possible to request certain position via uri eg. '/MediaServer/VideoItems/T-b70621a57705fe26c75f3a900374753e.mp4?mpTimeStart=500' which will be registered to mpTimeStart variable?
HTTP Pseudo-Streaming
Re: HTTP Pseudo-Streaming
In any case, the player does not understand the answer (mp4 specific)Nazar78 wrote:
So is there any way I can call a specific time from the http link other than using the time interval?Eugene wrote:Hi,In any case, the player does not understand the answer (mp4 specific)Nazar78 wrote:
For mp4, I think, it's impossible (only with transcoding or play from the beginning and GoTo).Nazar78 wrote:So is there any way I can call a specific time from the http link other than using the time interval?Eugene wrote:Hi,In any case, the player does not understand the answer (mp4 specific)Nazar78 wrote:
Hi Eugene,Eugene wrote:For mp4, I think, it's impossible (only with transcoding or play from the beginning and GoTo).Nazar78 wrote:So is there any way I can call a specific time from the http link other than using the time interval?Eugene wrote:Hi,In any case, the player does not understand the answer (mp4 specific)Nazar78 wrote:
Let's say it's not only for mp4, is there any way I can offset to a specific time during transcoding from the web-navigation by using URI query eg. "?starttime=500". I've embedded a JW Flash Player into the WMS web-navigation. It can play the ffdshow transcoded content, only problem is that I can't forward to a part where the content hasn't been loaded. JW Flash Player supports HTTP Pseudo-Streaming where the player can call the time offset using URI. I just need to know how to implement this with WMS via URI.
You can try TimeSeekRange.dlna.org: npt=500.00- in request header, but it will be a transition based on file size.Nazar78 wrote:Hi Eugene,Eugene wrote:For mp4, I think, it's impossible (only with transcoding or play from the beginning and GoTo).Nazar78 wrote:So is there any way I can call a specific time from the http link other than using the time interval?Eugene wrote:Hi,In any case, the player does not understand the answer (mp4 specific)Nazar78 wrote:
