Released version "Wild Media Server (UPnP) v1.12.1
Update files
How to update the program:
1. Download the update file.
The program can be updated from the distribution kit - http://www.wildmediaserver.com/download.php
  • Wild Media Server (UPnP, DLNA, HTTP) v.1.12
  • 1. Added device configurations:
    • "Philips BD Player (UPnP, 16:9, 720x406)";
    • "Boxee Box (UPnP, 16:9, 720x406)";
    • "Samsung Wave (DLNA, 16:9, 720x406)";
    • "Toshiba TV 2011 (DLNA, 16:9, 720x406)".
    2. Added reading of keywords when scanning photos, added column "Keywords" in the table of photos, added folder "Keywords" to the section Photo.
    3. Added ability to play rtmp-streams from any minute via the folder Transcoding (required field Duration).
    4. Added Slovac translation file, updated Bulgarian translation file.
    5. You can delete the folder "CD/DVD/BD Images (ISO)" and iso-images will be available in the folders "All ..." and "Media resources folders".
    6. Changes at reading of ID3-tags on operating systems with an Oriental language by default.
    7. Added ability to save a list of media resources in HTML, XML, XLS, TXT, RTF formats (List [Movies, Music, Photo] - right click - "Save to file").
    8. Added ability padding streams with null packets (Settings - Devices - choose a device - Settings - Transcoder - "Files, subtitles" - Padding),
    can be useful if the device interrupts the playback of transcoding content.
    9. Updated device configurations for Samsung TVs (Padding - Suffix - 60 seconds).
    10. Updated the transcoding profile "Internet-television" - added support for subtitles, added support for splash screen in beginning of video.
    11. Added splash screen - tvsplash.mpg to the folder "?:\Program Files (x86)\Wild Media Server\Presentation\Images"; settings in the program -
    Settings - Devices - choose a device - Settings - Transcoder - "Files, subtitles" - "Internet-television" - "Splash screen";
    unfortunately, VLC creates a stream with wrong timestamps, the device can interrupts the playback.
    12. Added script "Scan folders", you can make the scan button on the main form of program (Settings - Processing - "Scan folders" - Edit - turn on "Button on the main form").
    13. Updated transcoding profile "Movies - DirectShow - WMV", changes for Windows 7, added support for various formats of video files.
    14. Updated subtitles module.
    15. Added modes "Automatic addition of new devices", "Allow access for new devices" (Settings - Devices).
    16. Added support for multi-angle DVD, restored support for changing titles of DVD-tracks.
    17. For wireless connections to the server name is added "- Wireless" (required re-adding connections in the settings of program -
    Settings - Server - "The list of authorized network connections").
    18. Added mode "Folder Transcoding in each folder of media-resources" (Settings - "Media-resources" - Service) - default on.
    19. Added setting for delay "Automatically scan directories when modified (creating, changing, deleting files)" (Settings - "Media-resources") default 60 seconds.
Update to version 1.12.1
    • "Samsung Galaxy Tab 10.1 (BubbleUPnP, SoftMediaPlayer - DICE Player, DLNA, 16:9, 640x360)";
    • "Samsung Galaxy Tab 10.1 (DICE Player, Web, 16:9, 640x360)";
    • "Sony Tablet S (DLNA, 16:9, 704x384)";
    • "Sony Tablet S (BubbleUPnP, SoftMediaPlayer - DICE Player, DLNA, 16:9, 720x406)";
    • "Sony Tablet S (DICE Player, Web, 16:9, 720x406)";
    • "ASUS O!Play (UPnP, 16:9, 720x406)".
    2. Individual settings of the client device:
    • added settings "Max video resolution", in case of exceeding the value of this setting, the video is automatically transcoded;
    • added a new page "UPnP, DLNA", part of the old settings transferred to this page;
    • removed setting "Authorization service", added setting "Turn off the authorization service" - unchecked by default;
    • added the group of settings "Transfer mode for data with unknown length (Transfer-Encoding: chunked)":
      • "UPnP-descriptions of services and media-resources";
      • "Files without transcoding and files with known size after transcoding";
      • "Files with transcoding";
      • "Internet resources and Digital TV resources (DVB)".
      By default data transfer mode of unknown length is now turned off, no matter, what device declares its support.
    • added setting "Processing the request of the trail transcoded file", by default checked.
    • added setting "Samsung DCM10", if enabled, the Samsung BD-players will be available to control subtitles, but you lose auto-selection parts Movies, Music, Photo.
    • added button "Description of the server" - editing UPnP-description of the server (in the parameters "DLNA, UPnP");
    • in setting "Max file size" of the transcoded file now you can specify a value -1, in this case, the server sends the resource to the device without Chunked mode and without the size of the resource;
    • added setting the transcoded file format and video encoding - FLV, may be used, for example, for video player Samsung Galaxy Tab.
    3. Updated the transcoded profile "Movies - DirectShow - WMV", added subtitles support with codecs FFDShow, added support DVD and BD media-resources, podcasts, internet-resources. This profile is used for video-player "Sony Tablet S". Requires Windows Vista, Seven, 2008, 2011.
    4. Updated German and Italian translation files.
    5. Added the transcoding profile "Movies - DirectShow - WTV - FFMPEG".
    6. Added support for uploading files (DLNA Upload), it may be useful for recording devices, that support this feature. Setting for the upload directory:
    Settings - Additional. To turn off file uploads enough clean "Upload files directory" or remove the corresponding folder of the sections Movies, Music, Photo.
    7. Added properties of the video: "Original width", "Original height", "Pixel aspect ratio", can be used in the transcoding profiles.
    8. Restored support Google Translate.
Carmen Marin
Re: Released version "Wild Media Server (UPnP) v1.12
Post by Carmen Marin »
I have a question regarding the following statement:
Are ISOs supposed to show up in the above mentioned forders regardless if the "CD/DVD/BD Images (ISO)" folder is deleted or not?
At this point I haven't deleted the "CD/DVD/BD Images (ISO)" folder and ISOs are not showing up in any other folder.
Carmen
lecureuil
Post by lecureuil »
have scan your folder media or restart wms after?
Device configurations "Sony Tablet S (BubbleUPnP, SoftMediaPlayer - DICE Player, DLNA, 16:9, 720x406)" and "Sony Tablet S (DICE Player, Web, 16:9, 720x406)"
BubbleUPnP, SoftMediaPlayer - provide DLNA-navigation, DICE Player - video playback.
BubbleUPnP does not support photos.
"Sony Tablet S (DICE Player, Web, 16:9, 720x406)" can be used with Internet Browser (free of charge).
SonyTablet.zip
(6.93 KiB) Downloaded 1383 times
2. Copy sony_tablet_s_dlna_dice_player.cfg, sony_tablet_s_web_dice_player.cfg to ?:\Program Files\Wild Media Server\Devices
3. Reload the program
4. Settings - Devices - choose a device - Type - "Sony Tablet S (BubbleUPnP, SoftMediaPlayer - DICE Player, DLNA, 16:9, 720x406)" or "Sony Tablet S (DICE Player, Web, 16:9, 720x406)"
5. Ok - Ok
P.S. Original Sony DLNA-client very limited, configuration may be later.
Carmen Marin
Yes, I did.
Yes, I did.
Folders [Movies] - right click - "Restore folders"
Carmen Marin
Thanks Eugene, it worked.
ramaral
Contact:
Post by ramaral »
Yes, I did.
Not work for me
ramaral
Carmen Marin
Ramaral,
Delete the ISO folder, go to Settings/Folder List, select your movie folder and Scan. It won't work if the ISO folder is not deleted (did not work for me, anyway...)
ramaral
Contact:
Post by ramaral »
Carmen Marin wrote:Ramaral,
Thanks Carmen Marin, it worked.
