Hi, i've tried to get internet TV working but i seem to still be missing something
i've added a link to "internet television" from a stream i checked using VLC (from shoutcast) but the stream doesn't show up as a movie on my tv?
is there any simple instructions on how to add internet streams?
-edit
Ok i've figured out what i was doing wrong before, and the movies are showing up now but the stream doesn't start, i just get a message saying the format is unsupported. maybe i'm going wrong somewhere when i add the movie link?
internet tv
Re: internet tv
http://www.wildmediaserver.com/forum/vi ... p=245#p245timbo wrote:Hi, i've tried to get internet TV working but i seem to still be missing something
-edit
Re: internet tv
yes i have gotten one stream to work using the steps provided in that post, however it still seems to be hit and miss?
for example when i add the following in the link option http://67.18.156.174:8000;stream.nsv and i test transcoding i get
[02fd2dbc] access_http access error: cannot connect to 67.18.156.174:8000
[02fd2dbc] access_mms access error: invalid HTTP reply 'ICY 200 OK'
[023d00b4] main input error: open of `http://67.18.156.174:8000;stream.nsv' fail
ed: (null)
[023d00b4] main input error: Your input can't be opened
but VLC streams it ok every time.
ed: (null)
Re: internet tv
Is it possible to stream internet tv with windows media player not with VLC? If yes how to setup it? For example I have a link to connect to my internet TV
http://www.bestrussiantv.com/player/str ... m=1&tz=xxx. Where x is user name and password.
I tried to add this link to WMS but I got message it can't paly.
Any suggestions?
Thank you
Any suggestions?
Thank you
Re: internet tv
In MONOGRAM GraphStudio 0.3.2.0 (http://blog.monogram.sk/janos/2009/06/1 ... udio-0320/) try File - Render URL, if the graph will be constructed and it can play (Start the graph), then I think you can connect to WMS.grafcable wrote: Is it possible to stream internet tv with windows media player not with VLC? If yes how to setup it? For example I have a link to connect to my internet TV
Any suggestions?
Thank you
Re: internet tv
Is it possible to set This http://wwitv.com/tv_streams/b5798.asx stream to Internet Tv ?
regularly works in Windows Media Player ,but it can not run in VLC
as of all other streams they works ok in VLC ,but I get message on may Panasonic V10 and Philips 9603d "could not play"
when I run test :
and " rc buffer underflow" forever
when I run test :
C:\Program Files\Wild Media Server>"C:\Program Files\Wild Media Server\wmsmpeg.e
xe" "C:\Program Files\VideoLAN\VLC\vlc.exe" -Idummy --language=en --sout-ffmpeg-
strict-rc --sout=#transcode{vcodec=mp2v,vb=60000,fps=24,width=400,height=576,sca
le=1,vfilter=croppadd{paddleft=160,paddright=160,paddtop=0,paddbottom=0},aspect=
16:9,acodec=mpga,ab=192,channels=2,samplerate=48000}:duplicate{dst=std{access=fi
le,mux=ts,dst="D:\Temp\WmsTemp\Test_b0eb0a91bc27f81cf49974d424732596.mpg"}} "htt
p://cctv.ws/9/BBC3"
[0ae649ac] dummy interface: VLC media player - version 1.0.5 Goldeneye - (c) 199
6-2010 the VideoLAN team
[0ae649ac] dummy interface: using the dummy interface module...
libdvbpsi error (PSI decoder): TS discontinuity (received 12, expected 0) for PI
D 0
D 66
rc buffer underflow
rc buffer underflow
rc buffer underflow
rc buffer underflow Re: internet tv
ZvonacIG wrote:Is it possible to set This http://wwitv.com/tv_streams/b5798.asx stream to Internet Tv ?
regularly works in Windows Media Player ,but it can not run in VLC![]()
<ASX version = "3.0">
<entry clientskip="no" skipifref="no">
<REF HREF="http://wwitv.com/online/connect.gif"/><PARAM NAME="ShowWhileBuffering" VALUE="true"/>
</entry>
<Ref href = "mms://62.162.99.150/OBN"/>
</entry>
<entry clientskip="no" skipifref="no"><REF HREF="http://wwitv.com/online/test.gif"/><DURATION VALUE="10:00:03.00"/><PARAM NAME="ShowWhileBuffering" VALUE="true"/>/entry> </asx>
Philips 9603d not supported MPEG Transport Stream, change ts on ps or mpeg1ZvonacIG wrote: as of all other streams they works ok in VLC ,but I get message on may Panasonic V10 and Philips 9603d "could not play"
when I run test :and " rc buffer underflow" foreverCode: Select all
C:\Program Files\Wild Media Server>"C:\Program Files\Wild Media Server\wmsmpeg.e xe" "C:\Program Files\VideoLAN\VLC\vlc.exe" -Idummy --language=en --sout-ffmpeg- strict-rc --sout=#transcode{vcodec=mp2v,vb=60000,fps=24,width=400,height=576,sca le=1,vfilter=croppadd{paddleft=160,paddright=160,paddtop=0,paddbottom=0},aspect= 16:9,acodec=mpga,ab=192,channels=2,samplerate=48000}:duplicate{dst=std{access=fi le,mux=ts,dst="D:\Temp\WmsTemp\Test_b0eb0a91bc27f81cf49974d424732596.mpg"}} "htt p://cctv.ws/9/BBC3" [0ae649ac] dummy interface: VLC media player - version 1.0.5 Goldeneye - (c) 199 6-2010 the VideoLAN team [0ae649ac] dummy interface: Warning: if you can't access the GUI anymore, open a command-line window, go to the directory where you installed VLC and run "vlc -I qt" [0ae649ac] dummy interface: using the dummy interface module... libdvbpsi error (PSI decoder): TS discontinuity (received 12, expected 0) for PI D 0 libdvbpsi error (PSI decoder): TS discontinuity (received 12, expected 0) for PI D 66 rc buffer underflow rc buffer underflow rc buffer underflow rc buffer underflow
Re: internet tv
This works fine in VLC
, but I do not understand how you found this original mms address?
but none of the stream does not work on Philips 9603D or Panasonic V10, simply will not run
I tried to leave transcoder profile empty, and all other transcoder profile and on TV none of the stream does not start
Re: internet tv
Can somebody help me with temporary file problem.Internet TV is working,but when I returning to the same channel again,WD TV LIVE starting to play the same content from the beginning as temporary file is not deleted.The same situation with all the channels.Temporary file deleting only after restarting the WMS.I tried to play with settings like "delete temporary file ......"
but nothing helps.I have 0.73.4 version
Re: internet tv
In interval "Termination transcoding, if the temporary file is not used during" (Settings-Transcoder) - this is normal.mreck wrote:Can somebody help me with temporary file problem.Internet TV is working,but when I returning to the same channel again,WD TV LIVE starting to play the same content from the beginning as temporary file is not deleted.The same situation with all the channels.Temporary file deleting only after restarting the WMS.I tried to play with settings like "delete temporary file ......"
