Thanks for a fast answer.
I already have a link under Internet-Television and I can see the link on my TV, but can't play it.
I'm not sure what you mean, where is this setting "access=file" and what soud I cange it to? (
http://127.0.0.1:1234)??
the profile transcoding "Internet-Television" produces errors when running a Test Transcoding.
C:\Program Files (x86)\Wild Media Server>"C:\Program Files (x86)\Wild Media Serv
er\wmsmpeg.exe" "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe" -Idummy --language
=en --sout-ffmpeg-strict-rc --sout=#transcode{vcodec=mp2v,vb=10,fps=24,width=720
,height=576,scale=1,aspect=16:9,acodec=mpga,ab=128,channels=2,samplerate=48000}:
duplicate{dst=std{access=file,mux=ts,dst="C:\temp\WMS\WmsTemp\Test_c1ed6443f95ec
fd6ea44061c8f62f8e7.M2T"}} "http://127.0.0.1:1234"
[0449746c] dummy interface: VLC media player - version 1.0.5 Goldeneye - (c) 199
6-2010 the VideoLAN team
[0449746c] dummy interface: using the dummy interface module...
libdvbpsi error (PSI decoder): TS discontinuity (received 2, expected 0) for PID
0
66
[044933bc] main input error: ES_OUT_SET_(GROUP_)PCR is called too late, increas
ing pts_delay to 1200 ms
[044933bc] main input error: ES_OUT_RESET_PCR called
rc buffer underflow
rc buffer underflow
rc buffer underflow
rc buffer underflow
and so on...
Tried out every transcoding profile + the custom SopCast, No luck so far
Thanks for the help
