Hi.
I wish to know if there is a way using Wild Media Server scripting to get folder random sort re-sorted?
I wish to get the folder 'All the music' with a random sort that changes every day.....
If somebody can help...
Random sorting using script
Re: Random sorting using script
Folder "All Music" - right click - "Random order"MathieuM68 wrote: I wish to know if there is a way using Wild Media Server scripting to get folder random sort re-sorted?
MathieuM68
Hi.
Thanks for the answer, but my problem is that once I made this, the random order is always the same.
I mean :
If I have music A, B, and C
Then setup random order on all music folder.
If I connect using a client, I will get for example B, C and A
I re-connect again, still B,C and A
etc.
The order will never change, until I re-select manualy <Random Order> on the folder.
My goal is to automate this once per day....
I mean :
etc.
Shuffle is not stored, but the list can be cached, and server, and device.
Service - Media database - Refresh Info ?MathieuM68 wrote: Thanks for the answer, but my problem is that once I made this, the random order is always the same.
I mean :
etc.
MathieuM68
Hi.
I've not tried this one, but my main concern is that I want this to be done automaticaly.
So, I was thinking about creating a script to will run once per day, and will do the stuff....
Settings - Processing - ...
WmsFindMediaFolder('0').Properties[1234567] := Random;
WmsDatabaseAutoSave
end.-
MathieuM68
Thanks a lot!!!!
I presume I must use this script as is, it will sort the 'All Music' folder?
And if I wish to do the same for the 'Favorites' folder, could you give me the related script?
Just automation for "Service - Media database - Refresh Info" or RenewMathieuM68 wrote:Thanks a lot!!!!
MathieuM68
Perfect! Thanks for your support!
