Hi.
I have a Kathrein USF 922 Sat-Reciever. From this device I'm able to connect to all other DLNA media server which I've tested. Unfortunately, Kathrein did'nt found the WMS. I've tried dlna 1.0, dlna 1.5, D-Link and Web from the settings dialog. The list of authorized network connections and client devices are empty (tryout version). The Kathrine is in the same network (192.168.2.xxx) like my other devices (PS3 and iPhone) which all could connect.
What settings shoud I try?
Best regards
						Connenct from a Kathrein Sat-Reciever
Re: Connenct from a Kathrein Sat-Reciever
						WMS at search is finding a device ?saintetiennema wrote: I have a Kathrein USF 922 Sat-Reciever. From this device I'm able to connect to all other DLNA media server which I've tested. Unfortunately, Kathrein did'nt found the WMS. I've tried dlna 1.0, dlna 1.5, D-Link and Web from the settings dialog. The list of authorized network connections and client devices are empty (tryout version). The Kathrine is in the same network (192.168.2.xxx) like my other devices (PS3 and iPhone) which all could connect.
				saintetiennema
yes, there are two entries:
1.: UFS-922 (current IP)
2.: Linux/2.6.23.17-MB411_7109-ST SDK, UPnP/1.0, Portable SDK for UPnP device/1.6.4
I just tried to enable this entries but it dosen't work, either.
Try "Default device (not DLNA, 16:9, 720x406)"saintetiennema wrote:yes, there are two entries:
				saintetiennema
Sadly, it dosn't work.
Debug log can be enabled in Settings-Additional. Same place a debug log can be viewed. Examine yourself or attach to the archive on the forum or send to support@wildmediaserver.com.saintetiennema wrote:Sadly, it dosn't work.
