I am trying WMS with my Wdtv live. Either WMS or WDTV are using the newest version/firmware.
During my test, I noticed an issue. When I added a folder with some rmvb files, it looks WMS can scan it and add all files correctly. but each time, when I use WDTV to browse "Watched Folder", it is frozen, and I have to reboot my WDTV.
Is there any body find the same issue?
Thanks in advance.
Can WMS handle rmvb format?
Re: Can WMS handle rmvb format?
If you use the Preview mode, the problem may be in this - rmvb automatically transcodesiceberg168 wrote:I am trying WMS with my Wdtv live. Either WMS or WDTV are using the newest version/firmware.
iceberg168
No, the WDTV is in List mode. And all rmvb files are working fine with Tversity and PS3MS.Eugene wrote:If you use the Preview mode, the problem may be in this - rmvb automatically transcodesiceberg168 wrote:I am trying WMS with my Wdtv live. Either WMS or WDTV are using the newest version/firmware.
