Hi folks, I've just started using wild, and so far so good, but I'm having a bit of trouble getting around the library. I want to avoid as many button presses as possible with my remote, so I'm trying to figure out how to seperate my movies from my tv shows. At the moment, they're all under "all movies" (which is the only one that will show thumbnails), so it makes it a little confusing when I have 200 episodes mixed in with movies. I could use collections, but thats a lot of menu navigation.
Anyone have any suggestions on how to sort these out? Thanks!
(ps: streaming from win7 to a wdtv live)
Question about sorting
Re: Question about sorting
On the right mouse button in the folder tree - Structure of media resources - On the right mouse button - Add folder - TV Shows - Type - Dynamic (script) - button Script - Expression
OK-OK-Close-Renew
You can create a root folder "TV Shows" and link it to the collections folder TV Shows (if exists)sparky wrote:I've just started using wild, and so far so good, but I'm having a bit of trouble getting around the library. I want to avoid as many button presses as possible with my remote, so I'm trying to figure out how to seperate my movies from my tv shows. At the moment, they're all under "all movies" (which is the only one that will show thumbnails), so it makes it a little confusing when I have 200 episodes mixed in with movies. I could use collections, but thats a lot of menu navigation.
SourceFolder: TWmsScriptMediaItem;
SourceFolder := WmsFindMediaFolder(mfVideoCollectionsItemID, 'TV Shows');
if SourceFolder <> nil then
WmsDatabaseLinkFolder(SourceFolder.ItemID, FolderItem.ItemID)
I have created the script as above, now there is a new root folder called TV Shows.
How to use it now, how do i get my shows in there??
Thanks for ur help.
Thanks for ur help.
