Feature Request - Movie Plot
2Old4DigitalLife
Re: Feature Request - Movie Plot
Post by 2Old4DigitalLife »
Mine shows 1.01.24.
Sounds like I need to download upgrade and install it using USB thumbnail drive.
Because in auto upgrade mode, tell me I do not need to upgrade.
Do you think this upgrade corrects some issues related to WMS?
2Old4DigitalLife wrote:Mine shows 1.01.24.
Sorry, 1.01.11. I checked this issue, I have not. If you specify the link information is loaded, I can verify it.
2Old4DigitalLife
I am assuming you are referring to IMDB link, if so, here:
http://www.imdb.com/title/tt1209377/
And I attach snapshot of pascalscript that I changed based on your recommendation.
Script change.JPG (113.54 KiB) Viewed 9564 times
2Old4DigitalLife wrote:I am assuming you are referring to IMDB link, if so, here:
After loading in the description & no, and no problems with viewing the description on WDTV Live.
