1.) what do you mean? A go-to-function in player? S370 doesnt have one. I mean, forwarding works, but with no sound. With mkv oder audiofiles no problem. The avi-files are transcoded for subtitles. But even without subtitletranscoding theres no sound.
2.) not working. Tried that before. A message appears for a microsecond, but the playlist is not showing up.
Sony blu-ray players: BDP-S370 / 470 / 570 / 770
Re: Sony blu-ray players: BDP-S370 / 470 / 570 / 770
In the PS3 is. Via the folder Transcoding you have a choice of playback from chosen minute.moqwai wrote:1.) what do you mean? A go-to-function in player? S370 doesnt have one.
What is transcoding profile is used? The player displays information about the current stream ?moqwai wrote: I mean, forwarding works, but with no sound. With mkv oder audiofiles no problem. The avi-files are transcoded for subtitles. But even without subtitletranscoding theres no sound.
If possible, attach an example of such a file (in archive) or just text.moqwai wrote: 2.) not working. Tried that before. A message appears for a microsecond, but the playlist is not showing up.
1.) Transcoding-profile is movies (primary) for divx. The player shows accurate values (Divx, Mbps, Audiocodec (mp3 e.g.)), even after forwarding and no sound.
No-sound-problem affects not all files, but i would say 90% of the tested files.
Found the intervall-option in transcoding folder.
2.)
It is a simple m3u-file with content like that:
2.)
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\01 You Think I Aint Worth A Dolla.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\02 No One Knows.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\03 First It Giveth.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\04 A Song For The Dead.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\05 The Sky Is Fallin.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\06 Six Shooter.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\07 Hangin Tree.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\08 Go With The Flow.mp3
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\09 Gonna Leave You.mp3
If there is a problem in the content, which is not transcoded, it is a problem player, the server simply transfers the file with position, specified player'smoqwai wrote:1.) Transcoding-profile is movies (primary) for divx. The player shows accurate values (Divx, Mbps, Audiocodec (mp3 e.g.)), even after forwarding and no sound.
Loading playlists are supported only for Internet links.moqwai wrote: 2.)
It is a simple m3u-file with content like that:Code: Select all
D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\01 You Think I Aint Worth A Dolla.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\02 No One Knows.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\03 First It Giveth.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\04 A Song For The Dead.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\05 The Sky Is Fallin.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\06 Six Shooter.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\07 Hangin Tree.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\08 Go With The Flow.mp3 D:\Musik\RockPop\Queens of The Stone Age\(2002) Songs For The Deaf\09 Gonna Leave You.mp3
For songs: create a playlist - drag and drop songs into his.
P.S. You can drag and drop a folder from the Watch folders.
Files are playing perfectly from stick and with WMP12. So, its not the player.
I've created playlists like that. Working good. But there's the problem with stopping. Not reproduceable, not wtih the same files. Mentioned it some posts above. Any hints on that?
The computer does not have tasks that at times much load system ?moqwai wrote: I've created playlists like that. Working good. But there's the problem with stopping. Not reproduceable, not wtih the same files. Mentioned it some posts above. Any hints on that?
For example, the program file-sharing networks.
No, it happens on idle as well as on normal working activity. So theres no hint. And its not happening when playing from a folder. Only at playing by playlist
For device a playlist and folder is the samemoqwai wrote:No, it happens on idle as well as on normal working activity. So theres no hint. And its not happening when playing from a folder. Only at playing by playlist
Nevertheless its working with folders. Maybe an update from your server solves the problem. Maybe i reset all configurations and setting up again from stock. Changing and trying a lot recently. Perhaps its twisted somehow.
http://www.wildmediaserver.com/forum/vi ... ?f=3&t=502
1. Added device configuration "Sony BDP-S370/S470/S570/S770 (DLNA, 16:9, 720x406)".
