Update file from version 0.73
How to update the program:
1. Download the update file.
Wild Media Server (UPnP, DLNA, HTTP) v.1.00
  1. Podcasts:
    - added ability to read a list of media resources without RSS-feed, using a special
      script;
    - added ability to use a special script for Media resource link from a page media
      resource (used for reading properties of video, audio, transcoding media resources),
      the link is returned in variable MediaResourceLink;
    - the possibility to download additional properties podcasts using scripts (button Script),
      in the script is available variables PodcastItem - current item database of media
      resources, PodcastXmlItem - element description of the current podcast in the feed
      podcasts;
    - added modes transfer podcasts to media device (Transcoding, Original link,
      Original stream);
    - the possibility to inherit settings from parent folder of podcast feeds (for example,
      may be useful for Youtube);
    - added setting the display mode of media resources in the main form
      program (table, cards);
    - added ability to specify internet links to folder thumbnail (button "Internet link
      to thumbnail);
    - button to save the description of the podcast (in field Link), is included in the
      description and the transcoding script, if it is defined. For load a saved description
      simply drag the saved file from Windows Explorer into the main form;
    - in the navigation on the media device added to the folder "Update podcasts";
    - podcast gallery http://www.wildmediaserver.com/forum/vi ... f=20&t=259.
  2. Folder list of media resources (Settings-Media-resources):
    - added mode "Each film in a separate folder", can useful if used such a structure
      storing movies. The folder extra includes a folder of information from the Internet
      database (if it is loaded) and Transcoding folder.
  3. Transcoding profiles:
    - updated transcoding profile "Music - FLAC ", deleted transcoding profiles
      "Music (FLAC-DTS)", "Music - FLAC - LPCM", recommended restore transcoding
      profile  "Music - FLAC" from the distribution (Settings - Transcoder - Profiles -
      "Music - FLAC "- Restore);
    - updated transcoding profile "Movies - TsMuxer", can now be used to transcode
      any files in the format of MPEG Transport Stream, if the film selected subtitles,
      then to perform transcoding video track to MPEG2. Removed the use of profile
      transcoding "Movies - DirectShow - TsMuxer". Recommended restore transcoding
      profile  "Movies - TsMuxer" from the distribution (Settings - Transcoder - Profiles -
      "Movies - TsMuxer"- Restore);
    - updated transcoder FFMPEG, added support for file names in Unicode;
    - updated subtitles module, added support for file names in Unicode, changes for
      support dvb-subtitles;
    - the distribution kit of the program included loader rtmp-resources RtmpDump
      (http://rtmpdump.mplayerhq.hu). Added a setting number of attempts to resume
      loading rtmp-resources (Settings - "Media Resources" - "Internet Resources" -
      Podcasts);
    - in function WmsCreateDualPipe added parameter "Buffer size", default 1 MB,
      can be use, if at the start transcoding it hangs;
      for transcoding profiles added setting folder of transcoding profile.
  4. Settings-Transcoder-codecs, frame-Audio:
    - to the list of codecs added LPCM, is used in the profile transcoding
      "Movies - TSMuxer", "Movies - DirectShow - TSMuxer".
    - added mode "Hide in DTS LPCM", can be used if media device is connected to
      the receiver (DTS 5.1 (768 kbit, 1536kbit)).
  5. Added setting directory thumbnail movies (Settings-Media-resources-
     "Photo-resources, Thumbnails").
  6. For folders of media resources added mode "Shuffle", activate on right click
     of the mouse in the folder tree of media resources.
  7. Settings-Server:
    - added configuration mode "Prevent sleep mode while the server started"
      (the default mode is enabled).
  8. Added support for loading a list of internet media resources from playlists
     format XSPF (http://xspf.org), the format can be selected and for Web-mode
     the server.
  9. Reading information from Internet databases:
    - added function WmsAnsiToWideString, the function passed parameter
      code page of text;
    - to function WmsHtmlToText added parameter code page of text.
 10. Ability to change the XML-description of the server to be transferred to
     device can be used for cosmetic changes, which required for operation of the devices
     (Settings-Device-"Thumbnails, identifiers" - Identifiers media resources,
     the menu on right click "mouse" - Editing description server).
						Released a version "Wild Media Server (UPnP) v1.00"
				DooBop
Re: Released a version "Wild Media Server (UPnP) v1.00"
v1.00 will be uder license ? What about previous versions?
DooBop wrote:v1.00 will be uder license ? What about previous versions?
Wild Media Server (UPnP, DLNA, HTTP) (version 0.70)
1. The trial mode expires June, 1st 2010.
