How to stream DVDs - a Tutorial
Re: How to stream DVDs - a Tutorial
I have a ton of ISO files with the same problem (and I think this will work for them as well) but I was thinking of creating a script to handle this if I could find the database that contains the media structure. I could check which chapter is longest and set the rest as hidden automatically (or at least most of, maybe some small hand-fixing would be required).
