Released version "Wild Media Server (DLNA) v1.53.3 (32-bit)
Locked
Update to 1.53.2
Wild Media Server (UPnP, DLNA, HTTP) v.1.53
1. Added support for transcoding music with visualization modules. Supported types of visualization modules: Windows Media Player, Winamp, BassBox, Sonique. Working capacity the modules may depend on computer graphics system.
2. Folder "Movies":
  • Added folder "Music (Visualization)". Through the navigating on the media device, you can select the active visualization module or turn on the random selection of visualization module.
3. The main form of the program:
  • in the status bar added the button "List of music visualization modules" (configure of modules, choose the default module).
4. Individual settings of the client device - Additional:
  • added settings of music visualization.
5. Added the transcoding profiles:
  • "Music (Visualization)";
  • "Music - WMA Lossless (DirectShow)".
6. Added device configurations:
  • "Samsung TV [E] (DLNA, 16:9, 720x406)";
  • "Sony BDP 2012 (DLNA, 16:9, 720x406)".
7. Individual settings of the client device - Transcoder - "Files, subtitles" - "Transcoding file parameters" - Padding - Suffix:
  • you can specify a negative value, in this case the padding of transcoded file will occur until the end of play media resource (determined by the duration of a media resource) + specified value (absolute).
Music (Visualization) on your DLNA, UPnP devices
Update to 1.53.3
1. Added support for iso-images of SACD-discs and dff-files (DSD and DST-encoding)
2. Added the transcoding module for SACD-files (http://sacddecoder.sourceforge.net/).
3. Added the transcoding profile "Music - SACD".
4. Individual settings of the client device - Transcoder - "Files, subtitles" - "Transcoding file parameters" - Music:
  • added configuration settings for maximum LPCM-transcoding parameters (Sample rate, Channels, Bits (size of sample), by default 44100, 2, 16), used for the transcoded file formats s16be, wav.
5. Updated the transcoding profiles "Music - FLAC", "Music - APE", "Music - WAVPACK", "Music - DVD-Audio", changes for support maximum LPCM-transcoding parameters (if the transcoding profiles changed, it is recommended to restore the profiles from the distribution kit).
6. The main form of the program:
  • in the track list of video files added the columns "Codec (profile)", "Codec (level)", "ReFrames", added reading the specified parameters at loading file properties, can be used to configure "Additional verification of support files".
Re: Released version "Wild Media Server (UPnP) v1.53 (32-bit
Update to 1.53.2
1. Updated German translation file.
2. Changes for music visualizations in Windows Service mode
Re: Released version "Wild Media Server (UPnP) v1.53.3 (32-b
Update to 1.53.3
Locked
