Dear Eugene,
I am using the Uitzendingemist (7 days Beta) podcast.
It works fine until after 2 minutes it suddenly stops playing on my Sony Bravia TV (700EX). This happens over and over again. On IE these programs work flawles.
Could you please be so kind to tell me what is wrong and how to fix this?
Morefield
PODCAST Problems
Re: PODCAST Problems
"Terms of use" - delete mpInternetItem - Ok - Ok - Ok
Folder "Uitzending Gemist" - right click - "Edit title" - "Transcoding
profile" - "Internet-television"
Settings - Transcoder - Profiles - "Internet-television" - Edit -morefield wrote: I am using the Uitzendingemist (7 days Beta) podcast.
Thanks for the quick response.
Made the changes you suggested, but still every item stops after app. 2 minutes. Can you check it once more?
What's the address of the page?morefield wrote:Made the changes you suggested, but still every item stops after app. 2 minutes. Can you check it once more?
http://beta.uitzendinggemist.nl/afleveringen/1042328 - no problemsmorefield wrote:http://beta.uitzendinggemist.nl/
No, if I play the link on my computer there are no problems. But if I play it from my tv, via the menu of WMS, every single item quits after two minutes.
Hopefully you can try to solve it?
Test transcoding with "Internet-television" ?morefield wrote:No, if I play the link on my computer there are no problems. But if I play it from my tv, via the menu of WMS, every single item quits after two minutes.
I have no problems with playback.morefield wrote:Hopefully you can try to solve it?
