Podcasts Gallery
Re: Podcasts Gallery
paltibet wrote:
Eugene wrote: RTVE now uses encrypted information about the video
Then, it doesn't work anymore, true?
Yes, now is not working
jababda
Post by jababda »
paltibet wrote:
alarma wrote:
alarma wrote:Eugene, could you add a podcast for http://www.rtve.es/alacarta/.
Something like the other TVs podcast. I do not know if it is possible.
rtve.zip
Recomendados, Ultimos 7 dias, Temas, Todos A-Z, Archivo TVE
I have updated the podcast file uploaded by Eugene.
Update:
rtve.zip
Thanks Eugene.
It doesn't work for me, probably sth that i'm doing wrong.
Test transcoding:
"C:\Archivos de programa\Wild Media Server\wmsmpeg.exe" -probesize 7000000 -analyzeduration 5000000 -i "" -f dvd -vcodec mpeg2video -b 8000000 -aspect 16:9 -copyts -pix_fmt yuv420p -threads 2 -acodec ac3 -ab 44
8000 -ar 48000 "C:\Documents and Settings\adolfo\Configuración local\Datos de programa\Wild Media Server\WMS\Temp\Test_77050a85e2571715d6f3c79e344539b5.mpg" -v -1 -loglevel quiet
: No such file or directory
Other podcast works fine
Thanks for the answer
im getting the same error message for abc iview, im running win 7 64 bit, and other podcasts work fine, any 1 have any ideas?
jababda wrote: im getting the same error message for abc iview, im running win 7 64 bit, and other podcasts work fine, any 1 have any ideas?
Thanks for message, new version http://www.wildmediaserver.com/forum/vi ... 4156#p4156
isopor
Post by isopor »
Forbes has many shows of great quality, for example: http://video.forbes.com/intelligent-investing/guide
I tried to watch them in WMS by adding the RSS link ("add podcast" option):
http://www.forbes.com/video/static/xml/ ... eds/80.xml
It updates ok in WMS ("update podcast" option). But when I tried to test it (option "test transcoding / default device"),
I got the error message:
"Invalid data found when processing input"
What can it be? Can you do a script to it if needed?
TIA
isopor wrote:Eugene,
TIA
Folder "Forbes.com Intelligent Investing" - right click - "Edit Title"
"The additional properties reading script RSS" - On - click "Edit Script"
Language: PascalScript
Expression:
  PodcastItem.Properties[mpiThumbnail] := PodcastXmlItem.Find('media:content').Attributes['url']
Ok
"Script for the links to the resource" - On - click "Edit Script"
Expression:
  sVideoPage: string;
  MediaResourceLink := '';
  if WmsRegExMatch('video=(.*)', mpFilePath, sVideoPage) then
    WmsRegExMatch('movieURL1 = "(.*?)"', WmsDownloadUrl('http://video.forbes.com/' + sVideoPage), MediaResourceLink)
Ok-Ok
isopor
Post by isopor »
Thanks Eugene! It's working now.
johnnyzero
BeatlesTube transcoding profile?
Post by johnnyzero »
I downloaded and installed the beatlestube.wdf file from here http://www.wildmediaserver.com/forum/vi ... 3729#p3729, but the videos won't play on my WDTV Live Plus ("Unable to Play the selected file").
They appear to be flash-based. Can anyone suggest the proper transcoding profile to use?
thanks,
JohnB
Re: BeatlesTube transcoding profile?
johnnyzero wrote:I downloaded and installed the beatlestube.wdf file from here http://www.wildmediaserver.com/forum/vi ... 3729#p3729, but the videos won't play on my WDTV Live Plus ("Unable to Play the selected file").
New version http://www.wildmediaserver.com/forum/vi ... 3729#p3729
johnnyzero
Thanks, Eugene. The new version works - awesome!
paltibet
Post by paltibet »
It woluld be possible sth for http://www.videobb.com ? :oops:
