I'm trying to stream http://cctv.ws/9/RaiSport. I have successfully added it into the Internet Television category. On my WDTV (with latest official firmware), when I launch it, it starts nicely. After about 15 seconds, I can see the framerate drop and the sound is loss.
Any suggested solution to my little problem?
Internet TV streaming on WDTV Live slows down
Shadowraven
Re: Internet TV streaming on WDTV Live slows down
The problem may be related to http://cctv.ws/9/RaiSport. Currently, VLC shows intermittently.Shadowraven wrote:
Shadowraven
My stream stopped working completely now. When I test the transcoding, I check the temp folder and it's creating the file with extension .smpg. When I try the streaming from my WDTV, the temporary file is smpg.trail (1e2c7a07bb93ce200602ea594e38f639.smpg.trail)Eugene wrote:Hi,The problem may be related to http://cctv.ws/9/RaiSport. Currently, VLC shows intermittently.Shadowraven wrote:
Would you know what the trail extension means?
Trail indicates that the device has requested an end to the file.Shadowraven wrote:My stream stopped working completely now. When I test the transcoding, I check the temp folder and it's creating the file with extension .smpg. When I try the streaming from my WDTV, the temporary file is smpg.trail (1e2c7a07bb93ce200602ea594e38f639.smpg.trail)Eugene wrote:Hi,The problem may be related to http://cctv.ws/9/RaiSport. Currently, VLC shows intermittently.Shadowraven wrote:
Shadowraven
That's probably a bug in the WDTV Live then. I reverted back to an older firmware version and the problem is gone. The extension is back to .smpegEugene wrote:Trail indicates that the device has requested an end to the file.Shadowraven wrote:My stream stopped working completely now. When I test the transcoding, I check the temp folder and it's creating the file with extension .smpg. When I try the streaming from my WDTV, the temporary file is smpg.trail (1e2c7a07bb93ce200602ea594e38f639.smpg.trail)Eugene wrote:Hi,The problem may be related to http://cctv.ws/9/RaiSport. Currently, VLC shows intermittently.Shadowraven wrote:
Thanks a lot for replying Eugene. You are the star of this forum
