WDTV Live can skip the folders Movies, Music, Photo after selecting a server. But this option is dependent on the manufacturer's server. Version 0.73.2 (http://www.wildmediaserver.com/forum/vi ... &f=3#p1359) adds the ability to edit XML-description of the server. You can use the following parameters description
1. <manufacturer>Microsoft Corporation</manufacturer>
<modelNumber>12.0</modelNumber>
2. <manufacturer>TVersity</manufacturer>
<modelNumber>103</modelNumber>
After the change required restart the server
